Ok, I need to know this in my mind. My spark plug tester states on the
packaging that "Flashing bulb indicates an ignition or fuel delivery problem" I find that counter intuitive, should it not flash as the spark plug fires? I had it on all four plugs with the tractor running and it flashes on all four.
Still chasing a losing power issue with not much left to look at so trying to gain some insight from the tester but how does a flashing bulb indicate a problem? Those of you that use one of these, does yours flash as the plug fires with engine running?
