(quoted from post at 10:28:09 11/04/19)
What does coil voltage have to do with it ?
Unless the machine has an AM radio . Use nonresistor wires and solid core wires if using points . If using solid state ignition use non resistor plugs and spiral wound ignition wires .
(quoted from post at 15:21:42 11/04/19) > 27. Copper core spark plug wires make a
lot of difference in spark quality as
compared to automotive resistor wires.?
Whoever wrote that wasn't good at math. If
you do the math, you'll find resistor
wires don't have significant loss in spark
energy versus copper.
That's not to say there aren't benefits to
using copper. But don't expect a hotter
spark.
(quoted from post at 12:47:59 11/04/19) Ron, to your question: "Is it still beneficial to use copper core spark plug wires if you have converted to 12 volt?"
1) First, regardless if 6 or 12 volt THAT ALONE doesn't determine what plug wires should be used.
2) Often in typical old tractor MAGNETO ignitions copper plug wire would be preferred over modern carbon core suppressor plug
wires. Similar in many old tractor stock battery and distributor coil ignitions (6 or 12 volt no difference) old fashion
copper plug wires (not carbon core suppressor) were used
BUT HERES A POSSIBLE DIFFERENCE
3) Since you later posted its a Pertronix Ignition SOME (not all) of those high energy systems use a degree of suppression in the plug wires be it spiral wound or other IE NOT copper core wires in SOME of the high energy Pertronix Ignitions.
BOTTOM LINE check with Pertronix and do as they suggest NOT what any of us here may guess.
John T
