Spark plugs/steering lube
I went to my local(2 hr drive)New Holland dealer the other day and got a new head gasket for my '48 8N. While I was there I got a set of Autolite Spark plugs. They are 216's is this the correct spark plug, I've read guys on here using 437's.
How do I check the steering lube oil level in a '48 8N. What kind of oil do I use? Can I use 80w90 gear oil, can I use the same oil in my tranny/diff? Is there a drain plug so I can drain and refill?
I'm using 80w90 in mine with no issues- it's a little thinner for cold illinois days. I think the 437's are just a hotter plug, but if it ran fine before and ain't an oil burner, you will be fine. I used champion h10's, h12's, and my new set are the al437's, and I can't tell a difference between the 3. To be honest though I haven't heard of using that plug in an N though. But I don't know everything. My wife says I don't know anything. She may be right. LOL
oh- and there are 3 drain plugs you have to take off to get all the tranny fluid out. When you refill make sure to check how full it is at about 4 gallons, as there could be up to a gallon of sludge in the bottom. If it was totally clean it would hold 5. I use the rest to cap off my steering box, but it doesn't leak either. If it did I hear cornhead grease is a great alternative to stop leaking boxes.
NovaNewfie.......the "original" sparkplug in 1939 was Champion H-10 and thru the 1952 8N. The AutoLite 216 is the equivalent of the H-10. The 1939 engine was designed for low compression, low 70-octane white gas. (NO ethel lead additives)
Modern NO-LEAD gas is 87-octane and FOULS the colder H-10 and 216. That is why we recommend HOTTER AutoLite 437's (gapped 0.025) Champion no longer make the equivalent hotter H-12. They make an RH-12, which is a resistor design to reduce radio interference and it takes a STRONGER sparkie coil than the sparkie coils used on N-Tractors.
And for the same reason, DO NOT USE modern anti-static carbon-core sparkie wire. USE old fashioned COPPER-CORE sparkie wire with soft flexible silicone insulation ......, Dell, yer self-appointed sparkie-meister
Mine had J8C champion plugs in it. I looked in the champion book and it called for H12. Its got a 12 volt round coil jimmied rigged to work on the front mount distributer with no resistor. It was fouling the plugs bad (needs ring job) so I opened the gap to 40 thou and it didn't foul near as bad. The wires on it are crap though looks like they took them off an old lawnmower.
Cornhead greese? The Al216 is what the Ford tractor shop had for a listing, a hotter plug won't hurt. Is there a drain plug for the steering box. I haven't found the fill plug yet (do you have to take the dash off?)
NovaNewfie.......take them COLD J8's OUT. No wonder yer fouling. J8's are 1/2" reach and H-10's are even shorter 7/16" reach. You'll be lucky to unscrew yer longer threaded J8's 'cuz that extra 1/2-thread showing gitts carboned and FREEZES and you haffa really bustta nutt to gitt'em loose. Understand???
Then install some AutoLite 437's gapped = 0.025" and they won't foul and you'll have eazier starting too. .......listen to the voice.....whoo-whoo (eirry spooky sound, eh?)
The change yer OLD DRIED OUT SPARKIE WIRES to new soft'n'flexible silicone insulated COPPER-CORE sparkie wires. Understand??? .......respectfully, Dell, yer self-appointed sparkie-meister
