spark plugs
G.V.J.
hey guys!
Wonder if others have had this experience ? Have a 110 garden tractor starts and runs great till yesterday went to start and no go took out plug good spark damp with gas . Still no go did this twice finally due to past experience went and got new plug and started right off ! Have had this happen with champion and autolite. Went to NGK because of this happening first time with NGK no fire under compresson? Does anybody make a good spark plug anymore?
THANK YOU!!
G.V.J.
(quoted from post at 09:18:34 11/23/14) hey guys!
THANK YOU!!
G.V.J.
Autolite 216 or 437 non resistor plugs and a solid core wire from coil to plug. End of problems.
Have to agree with B/D here. They have a solid piece of copper wire (pretty heavy too) all the way through. Only thing that will make them miss fire is if they get so much carbon on the insulator that the spark will follow the carbon down the insulator instead of across the gap. Simple cleaning with MAF sensor cleaner will fix it real quick.
Kohler 14 horse with cast iron block--in my book the most reliable and easy to work on motor that they ever made. Parts still available too!
