Spark Plugs
We us Autolite 3116 spark plugs in our Model As, Bs, and 70s.
a236699.jpg" width="650"
Hope this helps.
Don't need or want resistor plugs or wires on your old gas tractor unless you listen to AM radio or operate the tractor beside an airport. If using a Pertronix electronic conversion use spiral wound suppression ignition wires.
Any plug will foul if the coolant is not kept at least 180F , better 195F and the mixture leaned out. If it's an oil burner use a low ash straight weight oil rated SF-2 for two stroke Detroit diesels .
NGK (made in the USA NOT CHINA AUTOLITES) are Denso would be the better choice. Either NGK are Denso would be nickel plated to boot :)
http://www.sparkplug-crossreference.com/
Autolites are not what they use to be since they sold there sole to China. OH I forgot Autolite made a bad mistake and admitted it and moved there production of some plugs back the Mexico,,, sell them to mexkins I found better don't need your garbage...
