hooter
i have a 51 ford 8 n been setting for two years drained out old gas put in new battery doesn"t seem to want to spark don"t know much about this.
Start by sanding the points with wet/r/dry sandpaper. It may need new plugs, and at least a condensor if the points look ok. I would tear the carb apart and clean it. Check the distributer cap for corrosion on the contacts... clean as required. I'm not that familiar with the 8N, is that have a mag or coil?
Points most likely need to be cleaned. DO NOT use sand paper to do this because it will yes clean them but then in turn leave silicone behind that will cause you the same problem you already have. They make point files for just that type of problem and cost a great big price of $0.99. When a machine that has point sits the points corrode and that in turn causes the problem you have. Shoot even a piece of card board from a cereal box etc will clean the points
Dave, corrossion on distributor contacts wont bother the hivolt spark that has to jump a gap.The carb should be left alone when you have no spark.Trouble shooting is a step by step process not a change everything money wasting process.
