Special Tools for JD2030
Edgar
I'm looking for a pressure gauge (measuring range 0 to 3550 psi) which in the manual is supplied by Nuday Tool Company in Detroit Michigan. I'm gonna use this to troubleshoot the hydraulic pump of my tractor. If anyone know whether this company exist or has other sources, would appreciate your advise. Thank you
You don't have to buy it from them. Many places sell any gauge you want, and a lot cheaper than Nuday. Test equipment uses a high-end gauge and also escalates the price. In our Deere shop, we used cheap gauges and they worked find. We had a Deer calibrator, and checked them once in awhile. Just as accurate as the pricey gauges. You don't need something that fancy to get the job done.
You can buy 1000, 2000, 3000 5000, 10,000 PSI, etc. - for $20 each or less.
You're better off with a 5000 lb. gauge though, for measuring Deere tractors at 2250 PSI.
http://www.gaugestore.com/prodinfo.asp?number=38121
http://www.gaugestore.com/prodinfo.asp?number=38148
If you want to measure hydraulic system pressures on a tractor in the 2500 psig range, I would recommend you get a liquid filled 5000 psi gauge. Sometimes pressure transients (i.e.valve closing)occur that spike the pressure up a 1000 psig for an instant and it can damage your gauge.
As previously stated. You want your gauge reading mid scale at the desired pressure.
So a 0-5000psi gauge to read 2500psi range.
What is the 2030's hydraulic system doing or not doing?
Thanks for all of you who have replied.
The hydraulic system is producing a whissing sound while being operated. I look at the manual and the special tool was needed to troubleshoot.
I got the pressure gauge but has difficulty finding the right pressure hose adapter. Can't seem to find it on the website mentioned.
