Stan in Oly, WA
If I'd known I was going to get such good information in response to my question about silicone caulk, I'd have been more careful about what I asked. I haven't yet read all the information provided in the links which people included because I want to post another question first. Since people are giving such specific information, it seems like it might be a good idea for me to describe exactly what I need to use the caulk for.
A small but important part of the fence I'm building is on top of a short, wide retaining wall which was poured with 5' high lengths of 1" rebar sticking up every six feet. I welded horizontal lengths of 3/4" rebar 6" from the top and 6" from the bottom between each pair of uprights. Then I boxed everything in with vertical 2X6's and horizontal 2X4's separated by full length 1" spacers so that the frame appears to be 4X6 uprights and 4X4 cross members. An interior frame for each section of cedar fencing and a decorative 1X4 trim piece on top of each upper (nominal) 4X4, and post caps, will hide the spacers and joints.
The rebar was all sanded and painted but I still consider it the most likely trouble spot in this design. If water can get to it and it rusts, I could get rust staining the retaining wall, with no way for me to get at the location of the problem. That's why I would like to use the best type of caulk available to waterproof all the joints before I cover them with 1X4 trim pieces. I do not want to caulk any of the joints between the trim and the framing---places where the caulk would be visible and/or interfere with the painting or staining of the wood.
I hope that's clear. It's certainly long.
Stan
Stan
