Spectrum Cable
We have spectrum Cable and need a box for each TV. Could you put a splitter between box and first TV. Then run a cable to another TV. I realize you could only get the channel on first Tv on the second. I can't seem to find cable adapter from flat wire to Coax cable. Thanks
If you have a smart TV, Roku or some other streaming device you can load the Spectrum channel to each of those devices and eliminate Spectrum tuner box. A $30 Roku stick can replace the $8/month Spectrum tuner. I did this last summer. The local Spectrum store told me about this, the Spectrum website steps you through it.
Only if the converter box has a coax (RF) output. The "flat" cable is probably an HDMI cable, which is a digital interface and can't be split since there's bidirectional communication between the box and TV.
There's probably a composite video output from the box, composing of three RCA connectors. You should be able to run one TV off the composite video output and the other off the HDMI output. You'll only have HD on the HDMI TV set.
The other option is to downgrade your cable TV to internet-only, then use an antenna for local broadcast reception and stream other programming over the internet. Then the two TVs can receive different programs and you don't have to pay for cable or for the converter box. And if you're renting your cable modem, you should buy your own modem as well. Or, if really have to have cable, run the second TV off an antenna plus internet.
If you don't have a TV that is internet-capable, you can use an Amazon Firestick to get internet programming on any TV with an HDMI input.
The days of coax cable and splitters are getting to be OLD technology even though sure it can "work." I use HDMI and if necessary a person
can use an HDMI switch box where the sole input can be directed to one chosen TV etc. Ever since I got a ROKU stick and a Google Chromecast
(both presents from daughter, this year it was a Google Nest Hub) Im never going back lol. I get more then I could ever watch with the ROKU
and I can wireless "Cast" anything on my smart phone to a TV etc. I use these devices in BOTH home and RV.
John T
Yes you can.
Problem will be that all TVs connected "down stream" from the box will only be able to watch the channel that the box is set on. In simple terms. If the box is set to channel 125. All of the TVs will be on channel 125.
Anyways..
You can buy HDMI to Cable converter boxes. Warning... Get a box and not a converter cable. The cables do not work. Period. None of them.
That is actually not much of a 'problem'. You can get an "RF" universal remote control that you can use to change the cable stations from any room in the house. I had one years
ago just to handle multiple devices (including my cable box) that were in an "out of line of sight" cabinet.
If you are referring to an older TV with 2 screws to attach the wire, you need a matching transformer 300 ohm to 75 ohm. Old tech will hard to find.
Maybe I am not understanding, but I do not see why you would wish to cobble up your system when you can simply rent another device?
I've got a couple HDMI splitters from Amazing that transmit directtv to 2 tv's. They are powered splitters that need to be plugged in so they can boost the signal further than what the receivers can. We have 2 directtv receivers with each one having a splitter so we can have tv's in 4 rooms, one of which is the bathroom for the daily constitutional. After each of these I have an additional cheapie basic splitter to a 5th room but they only want to send a good signal to 2 tv's at a time so it doesn't work to have 3 tv's coming off of one of those splitters. Tried a 3 way switchable that didn't really work. Main thing is to have a powered splitter coming from and close to the directtv receiver. I'm running 50' and 100' cables to wind around the basement to do this so they boost the signal well. I'm sure I've got over a hundred bux for everything but would have to check my Amazing orders.
Would really like to find a bluetooth transmitter that hooks to the directtv receiver by hdmi with multiple receivers with hdmi connections all rated to carry ultra 4k. May be out there but I haven't searched for a while.
what did you use for splitter boxes and cables? The situation I have is at my dad's house. Directv guy came and installed a
new receiver box and it does not have a coaxial output on it it has HDMI to the living room TV but I need to figure out how
to hook up the kitchen TV.
(quoted from post at 23:33:26 12/29/20) what did you use for splitter boxes and cables? The situation I have is at my dad's house. Directv guy came and installed a
Good thing I can search Amazing for old orders. I ordered the CSRET ultra hd 4k x 2k HDMI splitter amplifier 1x2 1 in 2 out ver. 1.4 signal distributor with 1080p 3d compatibility (1 hdmi to 2 hdmi). However that comes up as unavailable. But it shows going to the OREI HDX-102 Premium etc. splitter for 14.99 each.
As with anything on Amazing, the devil is in the details and you can find the same thing with a different foreign name cheaper and higher or better. They have 3 way and 4 way splitters. Have to get the powered ones to push the signal. As usual, look at the you also might like stuff as well as the what others buy stuff.
For cable I bot the outdated stuff. Search HDMI cable and you want the new cable that has HDMI 2.2 standard. Last stuff I got was from the Ibirdie store which was Amazing's choice. Look for 4k HDR HDMI 2.2, 18gbps 4k 120hz, 4k 60hz (4:4:4, HDR 10, ARC, HDCP 2.2) high speed ultra HD cord. And for all I know there may be higher standards than the HDMI 2.2, HDCP 2.2. Compare anything to the Amazing Basics brand stuff as sometimes their pilfered copies are better but sometimes they are behind the newer standards.
Good luck. Let us know if you find something better. I can't buy anything on there without spending countless hours comparing brands, prices, reading questions, and countless reviews so I didn't do a total search for you.
I should add that the cable, over the air, and directtv doesn't really provide anything in 4K except directtv has about 3 channels with selected content if you like watching whales swim around the ocean.
My directtv won't send a 4k signal to the other 4k tv because the long old hdmi cable I bot doesn't pass the 4k signal. That is why I said buy the best cables now for when they do provide it hopefully in our lifetime. I did put a new short cable to the main tv and it passes 4k. I've been upgrading tv's to 4k even though there isn't really any 4k stuff and I don't do bluray or playstation. The 4k tv's do have better resolution than the 1080p and 720p tv's with the basic programming for what it is worth. Does it help in watching old westerns on the over the air channel, Grit TV, the answer is no but oh well.
