Speedi Sleeve
super99
Im not an expert by any means, but I have used a couple of them. This one threw me! I got the motor pulled out of the Oliver 550 today to fix the leaking rear main seal and took the flywheel off to find this. There is a lip almost all the way around the Speedi Sleeve that is high enough that I dont think theres any way to put a new seal over it without ruining the seal. I wonder if someone tried to finish driving it on from the outside. I ground the lip off and made it smooth enough to get the new seal on when it comes.
Ive had to wrap a thin flexible plastic sheet and use that as a way to get the seal past a rough edge like that. Plastic notebook dividers work good.
Even a piece of thin flashing would do it.
well just remove that seal then remove that sleeve and start over. that sleeve is destroyed. get a wide cold chizel and whack it across that sleeve and it will pull off by hand. be carful on that crank looks like i see grinding on there already.
Previous repair man did not drive the seal on far enough, and the flywheel mangled it when the bolts were drawn down. If the driver they give you with the new sleeve is not deep enough, you will have to fabricate your own driver. If you are lucky it will be a standard exhaust pipe size. If not, you will have to have someone turn you one. Lastly, the flange is designed to be removed after installation. Reach in there with a sharp chisel and nick it, then pull it out with needle nose pliers. There is a groove at the base of the flange where it is designed to tear off.
Accuse me of being over picky or whatever...I always checked the runout as per Manufactures specifications...or a Junior that I trusted checked and signed documentation.
Your $$$$'s
I was responsible for some MONSTERS in my forty-year carrier...LOL
Bob..
Someone forgot to take the shoulder off the sleeve probably what ruined the seal in the first place . Replace sleeve and remove the shoulder then if it wont drive on far enough to get passed the end of the crack youve got to cut the flywheel outside edge down was well
When I put the wear sleeve on the crank for a friend of mines Cat engine in his truck I put a plate on the crank with a couple bolts and pulled it on then to get the rest of the way used the old sleeve behind the plate in front of the new sleeve. Just took it till it was back of the edge or chamfer on the crank so it made a smooth place to slide on. Pressed seal in back plate the same way with the plate and a couple bolts on a flat surface.
When I have a rough area a seal has to slide over I wrap it with layer of electric tape. oil or grease the tape and carefully slide the seal over it.
I agree with what others have said along with my 2 cents worth;
-The existing sleeve was not driven on far enough
-The installation of the flywheel likely distorted the sleeve
-You definitely need a new sleeve
-The install lip can be removed if it creates clearance issues if it doesn't then leaving it on will not hurt anything
-If you do intend to remove the lip after installation nick or notch the lip with a pair of side cutters first so you have an easy starting point to peal it off with.
-Sleeves are available in various widths, one with a little less width that what is on there would clear the flywheel while still providing the required surface area for the seal to run on.
-If they will come out easily removing the dowels will probably give you enough room to install the sleeve with the supplied driver, if they wont come out easily one could drill a couple of holes in the install tool for the dowels to clear
On my screen with my eyes, the sleeve looks like it was installed backwards. Normally the 'flange' of the sleeve goes on first. There is a serration or tear groove between the flange and the main part of the sleeve to allow the flange to be torn away with needle nose while the rest of the sleeve remains. The only purpose of the flange is to give you something to drive against with the installation tool.
It looks like the seal was installed first and leaked. So the sleeve was installed 'sleeve side in/flange side out' to try and sneak it in under the seal without removing the seal to control the leak. I have no idea if that would be effective or not, but it probably explains why the flange is banged up the way it was.
