With respect, Scotch Locks are applied to stranded wire with a squeeze of a metal strip into and through the insulation. They promote corrosion, may damage the conductors, come loose, and I do not recommend them at all. I have repaired more systems that were "fixed" with these gizmoes" than I can count. JimWe called them, wire-nuts.
Or, scotch locks, they were made by 3-M.
How many trailer lights have been wired that way? How many of those have intermittent light problems? Same answer.With respect, Scotch Locks are applied to stranded wire with a squeeze of a metal strip into and through the insulation. They promote corrosion, may damage the conductors, come loose, and I do not recommend them at all. I have repaired more systems that were "fixed" with these gizmoes" than I can count. Jim
I hate those things.With respect, Scotch Locks are applied to stranded wire with a squeeze of a metal strip into and through the insulation. They promote corrosion, may damage the conductors, come loose, and I do not recommend them at all. I have repaired more systems that were "fixed" with these gizmoes" than I can count. Jim
I think they come from the factory corroded. I hate those things.They promote corrosion, may damage the conductors, come loose, and I do not recommend them at all.
I have two bags of 500 each that were on a shelf I bought at an auction. I have used maybe a dozen of them over the past ten years, mostly for temporary emergency repairs. Most of those worked until I replaced the whole wire. Some of them were more trouble than they were worth.With respect, Scotch Locks are applied to stranded wire with a squeeze of a metal strip into and through the insulation. They promote corrosion, may damage the conductors, come loose, and I do not recommend them at all. I have repaired more systems that were "fixed" with these gizmoes" than I can count. Jim
Application ?Years ago they used something I think called nurley nut or knurly nut. I'm wanting to splice some wire and my friend Google doesn't know about them. Maybe I have the wrong name. I think made of copper and the bolt was split and the nut pushed down clamping wires together.
It's funny you brought this up, as that was the recent diagnosis on my train layout. The suitcase connectors that feed the tracks from the buss were not conducting as they should & had to be re-crimped in spots. It explained why some of my engines were acting possessed. They rely on signals to the circuit board from the command station, as well as the juice to run them. If those signals come in crossed, data packets eroded, etc, bad things happen. Or nothing happens. So far I have three engines with boards that will light up, but not respond. Even to a master reset. Will most likely have to pitch those & get new ones.With respect, Scotch Locks are applied to stranded wire with a squeeze of a metal strip into and through the insulation. They promote corrosion, may damage the conductors, come loose, and I do not recommend them at all. I have repaired more systems that were "fixed" with these gizmoes" than I can count. Jim
