Split shims for on-shaft spacing?
Got a fair amount of play in one of the cylinder points on my JD 9300 backhoe. It would be great to be able to shim it without having to take that whole thing apart. I'm sure I'm not the first to have this want, so I have got to think that it is already "a thing" and that there is some sort of piece available to shim without fully pulling the pin. Thoughts or input?
Pressure off the pin and lower to a comfortable working height remove the locking bolt and push the pin to one side,put in a shim/s and then push the pin the other way and shim the other side,keep the fingers out of the holes in case anything drops.
AJ
They make special washers for that , they are hinged on one side . You fold them around the shaft and pound them together on the other side.
