Well the rear seal has been leaking and the clutch has been slipping. It was only doing it under load snowblowing. It got things heated up in there a bit. The flywheel is not warped but it does have some spider cracking in it. It does need to be turned but there does not seem to be any specification as to what minimum thickness is on flywheel. The old disc was fiber and I guess we are going to go back in with the same rather than the button onless you guys think otherwise. He thinks I am nut spending money on tractor but I cant buy another for that money and if I did probably first thing I would have to do is fix things on it too. Good to hear others have 30,000 hours. I know this one has had engine worked on...just don"t know how far. I was worried about things other than engine holding up like gears and such
