Splitting a 4010 LP
I have a bent pto shaft Its the one that fits in the seal . as i understand the tractor must be split to replace this shaft . any and all help is great . where is the best or only place to attach the spliting wheels thank you for your help.
Back when I supervised the splitting of JD tractors we used the special OTC stands that had a castor wheel to mount under trans housing(I've seen roll-able floor jacks used in this situation) and screw adjusted stands that bolted to side frames up by engine. We left front sitting still and rolled differential back. Some other technicians on this forum choose to roll frt end fwd & rearward and leave rear-end stationary.
You'll need to remove platform(floorboard) to access trans housing bolts and cover on dash to access fittings on scv hyd lines and light wires.
