I am curious if anyone has experience splitting a 50a or general guidance. I need to pull the engine for what I think is a rod bearing issue. I have the service manual now and have read the engine removal section. It has procedures for with and without loader. I had planned to remove the 4 pins at the lifting arms and lift cylinders and leave the fixed frame in place. Is this do able. It looks like it? 2nd question, it says to remove the backhoe. Is this for safety and balance? If so I would think I can remove just the boom and leave the drive station and controls, does that sound right? The book make no reference on what to remove.
Last question for now - It says that with instant reverse you need to replace 2 engine to trans bolts with 5 inch guide bolts to avoid damage to convertor and pump. It makes no reference to the bolt size. Does anyone know or have a good guess? The machine is 225 miles away and I would like to get the guide bolts ahead of time.
Thanks I am sure I will be back with more questions as this project proceeds. Hopefully there are some 50a experts out there.
