Bendeere
I need to know the ring gap on a 25 D bored .45 over. The factory bore size is 6 1/2". Also the piston tolerance to the cylinder wall mat be usefull. Call if needed 517 610 1282 thanks Ben
End gap is usually .003 to .004 per inch of bore. Piston clearance is built into the piston & depends if cast iron or aluminum.
