spongey loader
RIVIR
JD 4320 has a 148 loader when using it picking round bales it has a spongey feel to the loader , is it the loader or the tractor causing this, in cold weather the loader wont pick a bale off the ground until you runs the loader up and down a few times before
Any hoses been replaced? There maybe air inside the system. I'm still trying to get all the air bled from my 240 loader after replacing every hose.
if you have a filter in the system replace it, but it sounds more to me like you don't have enough fluid in the resevior. does the pump grawl when in use, if so, add fluid. i would think the breaking the hoses loose and flexing the cylinder a few times would get the air out real quick.
everything up to snuff from the outside fluid up filter changed no hoses were off , BUT my brother and i split the tractor to put new cluster pac s in changed seals bearings where needed while puttin back together, you fellows like to go from there what we might have done .will wait ur reply. RIVIR.
