Sprayer for Ferguson TO30
BoonRoto
I have a Ferguson TO30 tractor, I would like to buy a PTO sprayer with a boom for it but it is my understanding my tractor does not have a live PTO. What are some options?
Don't need live pto for a sprayer.Just idle down on ends,leave the pto run.I've sprayed with a non live pto M and H farmall for 30 years. In fact,did so today,and will do so tomorrow. 100 gallon trailer type,pto pump,8 row booms with 3 zones........
Don't buy too big a sprayer, 100 gallon tank on a trailer should be good especially if you got steep hills.
I have 8 rows (wide), 10 row narrow boom with 3 sections. I just turn off at the selector- lift handle straight out while turning.
I use this small sprayer for deer food plots, mostly in the woods, only sprays about 10'but it's good for tight areas. I can close one side if needed. Also have a spot sprayer about the same size. note the 12 volt battery for my 6 volt system. The little boom sprayer is about 20 gallons and spot sprayer is 25 gallons.
<a href="https://imgur.com/RLLuYyd">
RLLuYydl.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/pSziVaz">
pSziVazl.jpg" title="source: imgur.com"
</a>
It's funny how everybody thinks they need live pto, live hyd. 3-pt hitch, couple shift-on-the-go speed selections, 3-4 sets of remote hyd outlets on every tractor now days.
I used to drive the '39 Farmall H spraying corn, Dad would ride on the sprayer and make sure all the nozzels were working. Mowed a lot of hay with that tractor too, but the Super H with live hyd cleared plugged sickles quicker/easier. Bush hogged thousands of acres with that Super H. Nobody had even heard of an over-running clutch back then.
I have to admit, power steering WAS a nice accesory.
I have a MF135 and I use a 50 Gallon with 12 volt electric pump. I can cover 6 row 30" with no problem. I put on about 10 gallon per acer for water rate mix.
But the 135 is 12 volt
