I need to put Goal 2XL on some 8" wide garlic rows to knock down the broadleaf weeds. Need to use 4 oz per acre in 20 gallons of water, per the label. I can figure out from a chart the nozzle (tip) size needed at my tractor speed (4MPH), but the label says to use 4 nozzles on a row (2 on each side of the row with one pointed ahead and one behind). Since each of these 4 nozzles is essentially spraying in the same spot, I figure I need to have each nozzle sized so that it puts out 1/4 the 20 gallons per acre (GPA) rate. Do I got that figured right? Seems to me if each nozzle is putting out at the 20 GPA rate and each is spraying the same spot I'd get 80GPA put down in the row. But I'm just not sure I'm thinking about this right.
Pete
Pete
