Spraying oil
Our local farm supply house (Campbell's) sell a spraygun for solvents and oils. Has a steel quart can, a 6 inch blowpipe. You snap in you air hose with the chuck that you use to inflate tires. Pull the trigger for a spry, that is adjustable at the tip. Works great for solvents and oils.
Gordo
Neighbor uses oil mixed with diesel and sprays it with a pump up sprayer. Been doing it all his life.
Yep , I save my used oil and mix 50/50 with diesel and use a two gallon bug sprayer .
You can let all of the pressure out and pump it just once or twice and get just a little right where you want it or pump the heck out of it and cover a large area .
