Spreading Poo
Destroked 450
Location
Harned, Ky
Been doing some late fall spreading putting chicken litter 75 acres of our hay ground.
This new 22' litter spreading bed helped cut down on the number of trips we were making compared to the old 14' spreader wagon we've been using.
A little added nitrogen and potash in the spring and we should get a nice hay crop next year.
Have another 65 acres I'd like to spread on but a couple of neighbors and a church are to close to those fields.
Thats a nice looking spreader. And probably better not spread
to close to houses unless you are going to incorporate it
My uncle who lived next door had chickens. I think just the vapors from that manure made plants grow, especially in later years when chickens were in cages. Seemed like the fumes also worked like loctite on anything around it.
Looks like a nice rig, will it handle corral cleaning?
I have been looking for a good used one for some time but very few come up for sale.
hansen and young on line auction. praire farm Wi.
two trucks
03 sterling, current bid is $5100
ENDING on Monday
Plenty of turkey litter and hog manure is spread in my neighborhood and the smell does travel but it only lasts a couple days at most. As soon as the ground dries I will have four tons per acre of turkey litter spread on 240 acres surrounding my house and my sons house. If the wind is in the south we will have very potent aerobics coming our way for a couple days unless we get a foot of snow on it right away. Across the road from my house hog manure will be knifed in on a 66 acre field of mine. Even though it is knifed in it still smells. Its part of farming, two days of stink! 363 days of the year will be OK. By the way the worst stink we have ever endured was cattle manure spread north of our house.
(quoted from post at 17:03:46 11/11/20) hansen and young on line auction. praire farm Wi.
two trucks
ENDING on Monday
I would gladly give you double that for it and throw in a steak dinner if you could get it across the border for me.
Saskatchewan Canada.
Spreading manure-not as bad job. Hand loading the spreader--not so much. My every week job until I left home, and I don't miss it.
(quoted from post at 18:26:47 11/11/20) Very good!!I Wish I could get a small pickup load of chicken manure
Larry I would gladly give you a load, but the 1400 mile round trip would be a bit of a drive
But if youre up for it youre welcome here anytime
Spreading manure and the smell is kind of like a peeing section in a pool. no way to stop the smell unless it is worked in right away.
Hauled some from Firth to Hastings this
summer, we could only get 15 ton on the
side dumps.
At the feed lots and dairy we can get
upward of 27.
I asked a guy running a pull type spreader
how much it holds?
"50"
Thousand?
"Tons, is what they're rated for, I had 51
on the last load"
They were putting 50-51 ton on and
spreading to the far end of the pivot (half
mile) and coming back across the turn row
around the edge of the field.
Chicken litter is a lot different from other manures, it's usually pretty dry and doesn't weigh much were others manures have a lot of moisture adding weight.
Average weight of chicken litter is 31-36 lbs per cubic foot, the 22' spreader bed in the photo will only hold 10-12 tons depending on how high one humps it up.
The 6 million bird laying facility 5 miles away from me has caged chickens so no bedding, just the pure stuff. They were mixing corn stalks with it and composting but I dont think they do that anymore. From what I see of the side dump loads they pile in the fields the manure slumps and flattens out after it is piled so it must be pretty wet. A neighbor used to spread liquid chicken manure and it was the most gawdawful smelling stuff known to man. I did some work on his tanker truck once and my shop smelled for a year afterward. No liquid chicken manure is spread around here anymore thank goodness.
