springfeild 25 tractor
keatons
hello all, I have a springfeild 25 model 64a tractor and I cant figure the belt out it keeps throwing it and the clutch doesn't work. I'm just going forum to fourm for help I have a 63 manual but it is not right I tired a few times. I'll attach a few pictures of the tractor if anyone is curious or you think you may have it, thanks
Welcome to YT forums and ASAP parts. The most common issue with belt throwing is misalignment of the pulleys. this can be caused by a replacement pulley that is not the same offset as original, or poor design from the beginning. A worn belt is the second most common issue. when the belt wears, they can flip upside down, or at an angle causing them to climb the pulley flange and come off. The third is a loose belt or a tensioner that is not doing its job. Belts need to be snug, but not radically tight to stay on. There are also belt guides that are important to keep the belt in alignment especially if the belt is used as a clutch. Jim
hello, and thanks i have a picture of how the 1963 belts go and mines a 1964, ill go put the belt on when I get home and take a few pictures, thanks a lot ill attach a picture of the 63 belt dighram
