stabbing a TO30 distributor
chefparker
Father in laws TO30 died in the field. Distributor wasn't tight and jumped out of gear with camshaft. Need to reinstall. Can bump #1 to top dead center on compression stroke but don't know where to point rotor. Also couldn't see timing marks. Any suggestions would be appreciated.
If you are on the compression stroke, look through the timing window under the starter. Move the engine with a wrench on the cranknut til it's at 6 oBTDC. The rotor should be pointing at or near the #1 spark plug teminal in the cap(#1 is nearest the raditor) Pull the #1 plug wire out and put a paper clip in it or a bent piece od wire and hold that near a good ground. Turn on the key and rotate the distributor til you hear the spark snap. At that point your are statically timed. Tightenen down the distributor hold down and start 'er up!
