some of you may remember last year I picked up a real beater of a 950 and it had some big 14.9-28 tires on PA rims..
the good: the rims were 100% cancer free.. not a spec of rust. centers looked great too.
the bad: some idiot moron dufus welded the rims up darn tight.
one side is 100% welded. there is a beat all along the PA center to the rim, including the keepers and stops welded up and the bolt holes for the keepers. bands of metal were even added along the inside edge to facilitate even more welding. the other merely had 4 mostly evenly spaced around the circumference triangle pieces crudely buzzed on from center to rim.
worse: they were adjusted totally different!!!! had they both been adjusted similar and equal.. I would have left them and ran them.. but one side is dished in, other dished out, and adjusted in different spots so that the stance is significantly offset.
sad part is is that the rims and centers looked great.. no real wear.. heck.. look better than the ones on my 63 4000 and they were darn good too...
anyway.. I set them aside for another day and just thru a set of 11.2-28 on the 950 to get her going..
well.. today was the 'another day'.
felt like a project, and looked the rims over.
the 100% welded up one is a lost cause.. torching out all those welds would eat the rim upand ruin the center as well.. so I decided to leave that one fixed, and see about getting the other side cut apart, and either adjust it like the other and weld up if I can't get it to lock down tight, or if it will lock tight, then adjust it like the other then clamp down.
In wanting to save the rim and center I went sparingly on the oa, and opted to do much of the cutting with a die grinder and air chissle.
got the center free from the rim, and got about 80% of the weldment cut off. still need to clean up the center so I can unscrew it from the rim, flip, then screw it back on. upon further checking, the dufus welded some scrap on either side of the inner and outter grooved pieces on a couple places, so i will have to cut one of them out to unscrew the center normally.. no biggie.. it's on the outter edge he welded a chunk to it.. I can cut that off without ruining the grooved section.
manhandling the 14.9-28 tire was a lil harder than I thought it would be.. guess loosing 25 pounds this winter didn't help any
ran out of daylight and didn't feel like working with all that fumes and metal and cutter dust in the shop, so i called it a night at about 7:30pm.. besides.. ran out of gas and die grinder discs anyway... will pick up more tomorrow and finish cleaning up the edge of that center so it will glide thru the grooved rim slots.
already hit it with a good dose of pb oil to get it lubed, and pulled out the locking frogs and carriage headed bolts/nuts.
with any luck i'll have the centr out, cleaned up and reinstalled by this time tomoorow.. or if not, at least by friday at noon before i have to head out to work.
now I just have to figure out what tractor gets these darn tall tires...
soundguy
soundguy
