G6 at Snook, TX
I have to tackle the last two projects on my tractor. I need to remove the starter and put the new bendix on it. I have several questions:
1. Will I need to remove the Oil Filter housing prior removing the starter?
2. When I pull the starter I know that I am not supposed to remove the the long bolts all the way and that I need to have a nut on hand to keep the starter together. What is the bolt size and threading so I can pick up the correct nut?
3. In the removal process are there any other issues I need to know about?
When I re-install the starter, GB said that it was a booger, but it has to be done.
1. What trick or angle or tool do I need to get the new bendix on the flywheel?
2. Other than that, I cannot think of any other major issues with re-installation.
Thanks,
Thanks,
