starter spark
DinWa
Did some brush hoggin today, finished, parked tractor to allow cooling before putting to bed. Went to start her up and all i got was the super slow cranking of the engine, battery is good. I opened up the hood door, and tried cranking again. Then i noticed a spark coming from the bottom side of where the solenoid bolts to the starter. Removed all nuts and washers, sanded all surfaces till shiny, replaced same, still sparking. BTW this is a franken "n" with a front mount dizzy. Thanks to all you out there in "n" land in advance. You guys are great!
From your description I'm guessing your franken N has an early 8N starter set up because it has a front dizzy and a solenoid.
Sounds like you were on the right track.
If it sparks at the connection, its a bad connection.
Can you tighten the bolts/screws up any?
(quoted from post at 22:49:04 08/11/12) Did some brush hoggin today, finished, parked tractor to allow cooling before putting to bed. Went to start her up and all i got was the super slow cranking of the engine, battery is good. I opened up the hood door, and tried cranking again. Then i noticed a spark coming from the bottom side of where the solenoid bolts to the starter. Removed all nuts and washers, sanded all surfaces till shiny, replaced same, still sparking. BTW this is a franken "n" with a front mount dizzy. Thanks to all you out there in "n" land in advance. You guys are great!
f you are talking about a Ford 8N, then the solenoid case is isolated from everything......requires no case ground....works wired up hanging in free space. So if case is hot & makes a spark to chassis/engine iron, then it has internal short. No good. Replace.
Hi Royse, I was just admiring your cats' retrieval! Not Bad! Anyway, yes I did tighten up all nuts as much as I felt safe using a 1/2 in socket wrench.
Thanks DinWa
JMOR's post made me go back and re-read what you said.
Is it sparking from the mount to the starter or from one of the posts?
He is correct in that it shouldn't need the mount grounded, so there
should be no reason for it to spark at the mount.
Half inch socket wrench?
Yup it is an 8n. Guess I did forget that part. I was hoping you wouldn't say that! lol, anyway, thanks. Any idea what those are running these days?
It is sparking from the starter to the bracket. Yeah, a half inch drive socket wrench,(it was handy).
I guess I was reading solenoid and thinking starter, my bad! Solenoid sounds a whole lot better than starter, $ee what I mean?
My 52 8n did the same thing .There was bad connection between the starter and the block .I loosened the starter and sanded both surfaces. now its the easyiest starting thing on the place.
Working dog, I think I'm gonna try replacing the solenoid first, not too much money and an easy fix, if that don't work, then I'll try your suggestion. Thanks for your input though.
sparks meand bad / loose connections. if the sparking part is internal tot he solenoid. either pry apart and fix.. or replace.
