Starter, steering pump, parts
corelokt
Hey y'all,
First best Holiday wishes to everyone.
I'm wondering what steering pump, what starter, what steering cylinder and box seal kits fit my square type Ford 2000 gassed?
I also need nose cone tin.
corelokt,
Have you found the New Holland website yet? It has good parts diagrams. I've found it to be very helpful to use BEFORE going the New Holland dealer to acquire parts.
Good luck,
Tom in TN
What exactly do you mean by "square type 2000 gasser"? Do you mean the 3 cylinder models that had the square hood as opposed to the older 4 cylinder models that had the curved hoods, or do you mean more specifically the later 3 cylinder 2000 that had the square rear axle as opposed to the earlier 3 cylinder 2000 that had the round rear axle?
Do you have the numbers from the flat spot near the starter or the foil sticker under the hood? If so, those will tell you the date of assembly of the tractor, and then you will know which are the correct parts based on the date ranges of the parts descriptions on the New Holland parts site.
