1948jr
On a 265 Massey starter is CHATTERING tractor starts but makes an awful sound trying . does this mean STARTER is bad or something else?
could have broke some teeth on ring gear [first ] stop starting it pull starter and find problem could be starter drive or ring gear would be the first place to start
Could be low battery, weak battery, weak connection, failing starter, broken nose cone.
Check the battery and connections first.
Could be bad brushes. I had one like that. Also, Worn out front bushing. Loose bolts, broken nose cone from worn bushing and loose bolts. Fun stuff.
