i'd personally suspect the cap before the rotor.Could this be the rotor?
dang, sorry to hear it. was excited there for a minute.Okay, another day with 8n. Here is what I did today:
1. Replaced points and condenser.
2. I put a new 12V coil on it yesterday.
3. Installed a new resistor
4. New distributor cap and rotor.
5. Cleaned old plugs and checked wires.
It started and I was very happy. It ran very rough but it ran . I was trying to adjust carburetor and did manage to smooth it out some and then it dies. It ran for about 5 minutes. I tried starting it again but nothing. I checked for spark on all cylinders and no spark at all. Back to square one.
I then pulled the new coil and tested it and it seemed fine. I then pulled distributor and checked inside and again the retaining clip had moved. It was not seated. This has happened before. I didn't think about much before but this time It obvious something is going on with distributor.
I am thinking now there something seriously wrong with the distributor? Any thoughts would be appreciated. Thanks.
I wonder if maybe the ring got squeezed a bit too much and now has insufficient spring tension to hold itself in position. Maybe stretching it a bit to increase the tension will solve that problem. Appears the part is available:Okay, another day with 8n. Here is what I did today:
I know, I do that all the time. I must be dyslexic. I will correct the post. Blasphemy!!Glad to hear you got him running well Steve. BTW, not a big deal, but it's an 8N not a N8.
climbing on it backwards?I know, I do that all the time. I must be dyslexic. I will correct the post. Blasphemy!!
