My '49 8N, 12V Conversion, 6 V coil with extra resister, I am never sure how to use the tester on the coil.front mount will now start only when releasing the starter button. I burned up one starter and now I have a
ford tractor specialist rebuilt starter that spins over good but seems like the sparkies don't have enough spark under compression, (do plugs fire different under compression?) but I cant see that. I have a 3/16" blue spark out side on the manifold ground. Should I take of the dist again (13th time) and could the timing be too late? causing hard start? Would appreciate any advice.
Thank you, DN
Thank you, DN
