stearing box lube 8N
Early or late 8N steering box? They were different and fill plugs are different. Early used a 1/4 NPT plug, late used a 7/16-14 HEX Bolt. Don't pour oil down thru the
steering wheel acorn nut as shown in manuals or you'll end up with a real mess. I made my own special fill plugs by adding a Zerk fitting to the NPT plug and the 7/16
Bolt head as shown. Use Corn Head grease to lube. Some will disagree but I have never had any issues using it. Shown are pix.
USE CORNHEAD or 00 TYPE GREASE:
FORD 8N w/MY MODIFIED STEERING BOX LUBE PLUG, EARLY BOX:
FORD 8N w/MY MODIFIED STEERING BOX LUBE PLUG, LATE BOX:
FROM THE 8N OWNER'S MANUAL:
NOTE: TOP LH IMAGE. DO NOT DO THIS.
Tim Daley (MI)
Early or late 8N steering box? They were different and fill plugs are different. Early used a 1/4 NPT plug, late used a 7/16-14 HEX Bolt. NPT Plug has a 3/8 Square
head. Don't pour oil down thru the steering wheel acorn nut as shown in manuals or you'll end up with a real mess. I made my own special fill plugs by adding a Zerk
fitting to the NPT plug and the 7/16 Bolt head as shown. Use Corn Head grease to lube. Some will disagree but I have never had any issues using it. Shown are pix.
Tim Daley (MI)
