Steer pump replacement info w pix
IT should be on the back of the MCV. Have to pull the MCV to get to it. DRain trans oil first about 15-20 gallon. Might just as well chanfe the filter at this time if it has not been done very recently. Make sure the o-rings are in place when you put it back together.
Hello cbt welcome to YT! Best I can do is give you a link to the CNHI online parts catalog for your tractor. Also there is a split on the serial number 21000 and above when they went to the closed center hydraulics. The pump is behind the MCV which is the square block on the side of the transmission housing with several lines connected to it. I will also place a link to the repair manuals YT offers for you tractor, the first on listed would be your best option. Might try posting this again on the IH specific topic section.
CNHI IH 1586 online parts catalog
YT IH 1586 manuals for sale
