steering box 1952 8n
Would someone please send me a printable copy of the exploded view of a steering box on a 1952 ford 8n tractor. don't want to wait to order a manual .
THANKS , BILL
How about this? From the NH website .
http://agriculture.newholland.com/us/en/Parts and Services/Parts and Services/Pages/default.aspx
from the nh website as well:
hope it helps
soundguy
1 1 8N3548B Housing Assy., Steering Gear, Years: 01/01/1949-12/31/1952
2 4 PL PROCURE LOCALLY Bolt, Hex, Steering Gear Assy. to Transmission, 7/16"-14" x 1-3/8", Years: 01/01/1949-12/31/1952
3 4 PL PROCURE LOCALLY Plug, Expansion, 1-1/4", Years: 01/01/1949-12/31/1952
4 1 8N3509B COVER Cover, Steering Gear Housing, Cover & Tube Assy., Years: 01/01/1949-12/31/1952
5 1 PL PROCURE LOCALLY Washer, Lock, Internal Tooth, 1/4", Years: 01/01/1949-12/31/1952
6 1 PL PROCURE LOCALLY Screw, Fill Hd., Used as Filler Plug, 1/4"-20 x 5/8", Years: 01/01/1949-12/31/1952
7 4 PL PROCURE LOCALLY Washer, Lock, 3/8", Years: 01/01/1949-12/31/1952
8 4 PL PROCURE LOCALLY Bolt, HH, Cover to Housing, 3/8"-16 x 1-1/8", Years: 01/01/1949-12/31/1952
8 4 PL PROCURE LOCALLY Bolt, HH, Side Cover to Steering Gear Housing, 3/8"-16 x 1-1/8", Years: 01/01/1949-12/31/1952
9 1 C5NN3N716A BEARING ASSY Bearing Assy., Steering Column, Years: 01/01/1949-12/31/1952
10 1 8N3518 SEAT Seat, Steering Column Bearing Spring, Years: 01/01/1949-12/31/1952
11 1 8N3520 SPRING Spring, Steering Column Bearing, Years: 01/01/1949-12/31/1952
12 1 251293 SHAFT Shaft, Steering Gear Sector or Pitman, Single, Years: 01/01/1949-12/31/1952
13 1 251294 SHAFT Shaft, Steering Gear Sector or Pitman, Single, Years: 01/01/1949-12/31/1952
14 2 PL PROCURE LOCALLY Washer, Lock, 3/4", Years: 01/01/1949-12/31/1952
15 2 PL PROCURE LOCALLY Nut, Hex Jam, Steering Arm to Shaft, 3/4"-16, Years: 01/01/1949-12/31/1952
16 2 8N3552 THRUST BEARING Cup, Steering Gear Thrust Bearing, Years: 01/01/1949-12/31/1952
17 2 AJ3576A BUSHING Bushing, Steering Gear Sector & Pitman Shaft, Long, Years: 01/01/1949-12/31/1952
18 1 8N3570 SEAL Seal, Steering Column, Dust, Years: 01/01/1949-12/31/1952
19 2 8N3571 THRUST BEARING Bearing, Thrust, Steering Gear Worm, Years: 01/01/1949-12/31/1952
20 1 8N3575B SHAFT Shaft & Ball Nut Assy., Steering, Years: 01/01/1949-12/31/1952
21 2 8N3576B BUSHING Bushing, Steering Gear Sector & Pitman, Shaft, Short, Years: 01/01/1949-12/31/1952
22 1 8N3578 GROMMET Grommet, Steering Column, Years: 01/01/1949-12/31/1952
23 2 8N3584B Cover & Bushing Assy., Steering Gear Housing, Side, Includes: Ref. 21, Years: 01/01/1949-12/31/1952
24 2 87073S94 O-RING O-Ring, 2.500" ID x .139" Thk, Side Cover, Years: 01/01/1949-12/31/1952
25 4 D5UZ3591A SEAL Retainer, Steering Gear Sector Shaft Packing, Years: 01/01/1949-12/31/1952
26 2 86553476 SEAL PROTECTION Seal, Steering Gear Sector Shaft, Dust, Years: 01/01/1949-12/31/1952
27 2 86542743 ARM Arm, Steering Gear, Used W/8N-3503-B, Years: 01/01/1949-12/31/1952
28 1 C5NN3595B SHIM Shim, Steering Gear Housing, End Cover, .002, Years: 01/01/1949-12/31/1952
28 1 251296 KIT Kit, Shim, Steering Gear Housing, End Cover, .005, Years: 01/01/1949-12/31/1952
28 1 8N3595C Shim, Steering Gear Housing, End Cover, .010, Years: 01/01/1949-12/31/1952
28 1 8N3595D SHIM Shim, Steering Gear Housing, End Cover, .030, Years: 01/01/1949-12/31/1952
29 1 D6NN3600B STEERING WHEEL Wheel Assy., Steering, Years: 01/01/1949-12/31/1952
30 1 356515S36 WASHER Washer, Flat, 70" x 1.50", Years: 01/01/1949-12/31/1952
31 1 359295S7 NUT Nut, Blind, Steering Wheel to Steering Gear Shaft, 11/16"-20, Years: 01/01/1949-12/31/1952
32 2 8N33544A SHIM Shim, Steering Gear, Lash Adjuster, .063 Alt. W/B,C & D, Years: 01/01/1949-12/31/1952
32 2 8N33544B SHIM Shim, Steering Gear, Lash Adjuster, .065 Alt. W/A,C & D, Years: 01/01/1949-12/31/1952
32 2 8N33544C SHIM Shim, Steering Gear, Lash Adjuster, .067 Alt. W/A,B & D, Years: 01/01/1949-12/31/1952
32 2 8N33544D SHIM Shim, Steering Gear, Lash Adjuster, .069 Alt. W/A,B & C, Years: 01/01/1949-12/31/1952
33 2 8N33545 ADJUSTER Adjuster, Steering Gear, Lash, Years: 01/01/1949-12/31/1952
34 2 PL PROCURE LOCALLY Washer, Flat, 7/16", Years: 01/01/1949-12/31/1952
35 2 PL PROCURE LOCALLY Nut, Hex Jam, 7/16"-20, Used W/Adjuster, Years: 01/01/1949-12/31/1952
36 2 8N33546 PACKING Packing, Steering Gear, Lash Adjuster, Years: 01/01/1949-12/31/1952
37 1 8N33581 RETAINER Retainer, Steering Gear, Ball & Nut Bearing, Years: 01/01/1949-12/31/1952
38 1 356937S EYE Eyelet, Retainer to Steering Shaft, .273" ID x .215" Lg., Years: 01/01/1949-12/31/1952
39 1 NLS No Longer Serviced Panel Assy., Instrument W/Hole for Proofmeter, 8N, Years: 01/01/1949-12/31/1952
39 1 NLS No Longer Serviced Panel Assy., Instrument W/Hole for Proofmeter, 8NAN, Years: 01/01/1949-12/31/1952
40 1 PL PROCURE LOCALLY Bolt, Hex, 3/8"-24 x .86, Years: 01/01/1949-12/31/1952
41 1 PL PROCURE LOCALLY Washer, Flat, 3/8", Years: 01/01/1949-12/31/1952
42 1 PL PROCURE LOCALLY Nut, Hex, 3/8"-24, Years: 01/01/1949-12/31/1952
43 1 8N9889A QUADRANT Quadrant, Throttle Control, Years: 01/01/1949-12/31/1952
44 1 PL PROCURE LOCALLY Screw, Oval Hd., #12-24 x 3/8", Years: 01/01/1949-12/31/1952
45 1 8N9805A4 Lever, Throttle Control, Years: 01/01/1949-12/31/1952
46 1 NLS No Longer Serviced Support Assy., Instrument Panel to Hood, Years: 01/01/1949-12/31/1952
47 2 PL PROCURE LOCALLY Washer, Lock, 7/16", Years: 01/01/1949-12/31/1952
48 2 PL PROCURE LOCALLY Bolt, Support to Upper Steering, 7/16"-14 x 1", Years: 01/01/1949-12/31/1952
49 1 C7NN8N043A KNOB Knob, Choke, Years: 01/01/1949-12/31/1952
50 1 8N9700 ROD Rod Assy., Choke Control, W/Battery Ignition, Years: 01/01/1949-12/31/1952
51 1 8N9855 Plate, Governor Spring Anchor, Years: 01/01/1949-12/31/1952
52 1 PL PROCURE LOCALLY Bracket, Throttle Control Arm, Years: 01/01/1949-12/31/1952
53 1 PL PROCURE LOCALLY Bolt, Rod Bracket, 5/16"-18 x 11/16", Years: 01/01/1949-12/31/1952
54 1 PL PROCURE LOCALLY Washer, Lock, 5/16", Years: 01/01/1949-12/31/1952
55 1 PL PROCURE LOCALLY Nut, Hex, 5/16"-18, Years: 01/01/1949-12/31/1952
56 1 8N9806 Spring, Throttle Control Lever, Years: 01/01/1949-12/31/1952
57 1 8N9827 SPRING Spring, Governor Compression, 4.95" Length, Years: 01/01/1949-12/31/1952
58 1 PL PROCURE LOCALLY Nut, Lock, 1/4"-28, Years: 01/01/1949-12/31/1952
59 1 8N9807 Arm Assy., Throttle Control Lever, Years: 01/01/1949-12/31/1952
59 1 NLS No Longer Serviced Arm Assy., Throttle Control Lever, Kerosene {8NAN9807}, Years: 01/01/1949-12/31/1952
60 1 PL PROCURE LOCALLY Bolt, Rod to Cover, 1/4"-28 x 1-1/8", Years: 01/01/1949-12/31/1952
61 1 PL PROCURE LOCALLY Grommet, Starter Switch Lead, Years: 01/01/1949-12/31/1952
62 1 C0NN3C715A GASKET
