Steering drag link
You may have to use a torch to heat it, and then whack the side with a good size hammer. You can try the hammer or a blunt air chisel for enough vibration. The down side with heat is if the rubber protectors take damage.
Yes Sir. In fact, I brought a heat gun home today from work. Hopeful it works.
Along the lines of what Nordic said, I've used a big hammer (like a 2#) as a buck or support on one side and then smack the the opposite side with a 1# or 1 1/2# hammer. Might need to work around the joint a couple of times. Usually that hard smacking will loosen the joint because the metal is being minutely displaced....as long as you can get access.
I appreciate the nuggets of info. I’m shocked just how stubborn they’re being.
That's the way it is generally done. Like you, I always use a backup hammer but some don'teven bother.
