STEERING GEAR BOX
Lightner
MORNING,
ANYBODY KNOW WHERE I CAN FIND A STEERING GEAR BOX FOR A McCORMICK DEERING W4? MINE HAS ALMOST A FULL ROUND OF PLAY.
THANKS,
BILLY
Best fix the one you have unless it's physically broken.
Odds of finding a used one ready to run are slim. It will likely cost more time and money.
what makes you think you need a replacement the part in the bushings and bearings can be purchased. With that much playtsounds like the out-putlink is loose from the shaft
Lightner The bearings that are on the worm gear shaft are possibly completely worn out.Watch the steering wheel at the bottom for up and down movement between the wheel and the column while turning the wheel side to side.
