Steering Gone 89 Case 455C
Hi Guys, I was using my crawler to pull a log out of the woods the other day. No problems, got the log into the pasture and decided to cut
it in half so I could use a grapple on another tractor to carry it to the sawmill without tearing up the pasture. I hopped off, cut the log
in half unhooked the chain and hopped back on. Restarted tractor and took off only now I have no steering in hi low reverse or forward.
trans pressure gauge looks good and it moves in reverse or forward fine, just no steering.
A few weeks ago I was using it to removed a bunch of sticks that had washed down in front of a culvert. I thought I had lost steering for a
minute down there, but then it started working and I convinced myself that I just had the bucket too low in the mud and that was preventing
it from steering.
Any tips on what to check are much appreciated
Check to see if the high/low valve spools are shifting. Those valve spoo[s are 2 piece and can actually come apart inside the valve body. Everything looks and feels like they are shifting OK, but they don't. It's a simple fix. Take the rear cover off the back of the valve body and take out the defective spool. Get a new snap ring and press the two halves of the spool back together.
