I have a 1947 Ford 8N that I picked up to help take care of my 10
acres. I haven"t driven a tractor in some time.
Full disclosure . . . I flipped the tractor. Ugh. At first it seemed the
main issues were a bent steering wheel, a smashed up hood, the
radiator was destroyed.
So I ordered the parts, tore it down, replaced everything necessary.
Drained all the fluids and replaced them just to be cautious.
The tractor started right up like a dream. Drove like it did the day I
brought it home. Steering everything seemed fine.
And then SNAP . . . The steering shaft had been stressed and
broke down inside the cover. Up until it broke it drove perfectly
fine. I know because I was paying pretty close attention to
everything making sure it was all in good standing.
So I ordered a new Steering Shaft. Tore it down and pulled the
sector shaft. Slipped out the old steering shaft. Centered the new
steering shaft. Slid in the sector shaft. Everything seems to line up
fine. Fill the Steering box with SAE 90 and put it all back together.
Now I"m driving it, and if I turn to the right everything is perfectly
fine. However if I turn to the left it is very hard to turn. You can
hear it seem to bind up and squeek sometimes. Turning back to
center is the same it is tough and then kind of gives into the
center and again turns just fine to the right.
I haven"t driven it to much. I know that isn"t right. It was fine up
until I changed that steering shaft even with the one that broke.
Any help or advice would be helpful.
