Steering problem with 3020
Ive discussed this with Tim but I have another question. I got the steering valve rebuilt. THe power steering now works great, But I have no manual steering. I will turn the steering wheel and it will just keep going. It did do that when running but it stopped after I bled it. If it calls for pulling it off again then I will do without if the power steering keeps working good. Thanks for the help.
The check valve ball and spring probably got lost some where along the line,, maybe at a time before you got it, the only time you would need it is if you lost power and were flying down the road, hopefully this won't happen, it is posible to put the check valve ball and spring in without pulling the hole thing..
