stihl 031 crankcase vacum
jaw3047
My stihl 031 was at the shop the guy told me it needed seals at crank because a vacum is needed to pick gas up to carb. I have it torn down and put air pressure into crank case only lite air passes through seal behined chain sprocket. When I put air above piston air leaks faster past rings. I'm thinking he's wrong and it needs rings anyone run into this problem?
If an 031 gets a crankcase air leak it won't idle and just want to race - besides running lean an starving for fuel. Crankcase is supposed to hold 10 PSI. If it does leak, the cause is just about always the sprocket-side crankshaft seal - and it's pretty easy to fix.
If piston/rings/cylinder is bad - you'll be able oit see by taking off the muffler and looking into the exhaust port.
You have to take the muffler off anyway to block the exhaust port to pressure check.
I have muffler off what should I look for if rings are bad? I'm sure it leaks air on seal on sprocket side by blowing in carb opening.
Look for scoring on rings and/or cylinder wall, piston scoring, scuffing, etc. If all looks clean with normal wear, then it's probably fine.
Most damage occurs near the exhaust port. If it looks good there, then you assume the rest is fine also.
As to leaks, I assume you've already checked the vacuum/impulse hose that runs the fuel pump in the carb?
