With the help of the experts here, I found the overcharging problem. My Dad had hooked up the genny ground to the field connection on the VR.
While I was fixing that I rewired just about the entire system. Nice new wires and ends.
Started the thing up and no charge showing on the amp gauge. It pulses as you are using the starter, but when engine catches, the needle does not show any charge rate.
I shut it off and repolerized at least a dozen times. Even tried it while it was running. I just can't get it to charge.
To repolerize I momentarily shorted the bat to arm connections on the VR.
Am I repolerizing incorrectly? or is there something else I can check?
Thanks.
Almost forgot: '51 side mount, 6 v system, black rubber tires...........
Jim
Thanks.
Jim
