Again thanks for all the help in trying to ID this engine. I have included all the pictures again and added one more which shows the only mark I can find on this engine after tearing it down and cleaning it up. It is a number 2 cast into the block as seen in the picture (probably just for casting purposes). I took off the head, measured the bore and got 2.75", another person posted this message in my last post.
Just pull the head off and measure the bore with a tape-measure. Good idea anyway to verify the condition of the engine. You can stick the head back on later and you won't need a new head gasket. Then ID for an aluminum engine with points behind the flywheel as thus.
2.375" bore a model 8B/80000/820000
2.5" bore will be a model 100000
2.78" bore a model 110900
2.56" bore a model 130000
2.75" bore a model 140000
3" bore a model 170000/190000
I promise you there is not another mark anywhere on this engine as it is that I can see. Thanks again for all the feedback.
