stopping rust
bfullmer
Have a mid 70's corvette stored in barn what is best to paint on frame to stop the rust? I am looking for something that I can just brush on and leave it no primer or paint ?
Spray the undercarriage with motor oil....Yep motor oil. An old timer that worked with a friend of mine many years ago used to take the 4 quarts of oil from every oil change and put it in a cup sprayer and coat the under side of his car......Lasted for many many years I was told.
I use fluid film,it comes in spray cans,gallons or 5 gallon containers...and you can also brush it on. Part stores sell it and rural king also...I just bought 5 gallons and undercoated my chevy truck and our 06 impala..used 3 gallon on truck and 1 gallon on car...sprayed with fluid film pro gun 1 quart at a time...it's a mess but worth it to me.
Keith
(quoted from post at 17:38:03 10/21/14) Spray the undercarriage with motor oil....Yep motor oil. An old timer that worked with a friend of mine many years ago used to take the 4 quarts of oil from every oil change and put it in a cup sprayer and coat the under side of his car......Lasted for many many years I was told.
Spray the underside of the car at each oil change? Wow.
That is what he said..........Seems like overkill, but if you are a car nut and like laying under a car and spraying motor oil.......Come to my house and spray mine too.
For dealing with rust I love this stuff:
http://www.jamestowndistributors.com/userportal/show_product.do?pid=557
Followed by:
http://www.homedepot.com/p/Rust-Oleum-Professional-15-oz-Flat-Gray-Cold-Galvanizing-Compound-7585838/100142963
(quoted from post at 19:59:20 10/21/14)
That's what you have to do if you use motor oil, because it doesn't last.
Of course if you get under your car every 3 months, hose it down, and spray it with ANYTHING, it will last longer than if you do nothing... Any sort of non-corrosive liquid, grease, oil, paint, even nacho cheese, would preserve your car's undercarriage longer than nothing.
Most people do nothing.
I'll Third the POR-15, just make sure if you use it, do not get it on anything you do not want black, forever.... That stuff will not come off.
Parafin wax , the sort that cheap candles are made of , melted in kerosene and sprayed . Kero evaporates and leaves a film of water repellent wax behind that seems to last forever . Craft and hobby shops sell it in large blocks for a reasonable cost .
I run a vehicle up on a deck-over trailer ramp, hook log chain from ramp to trailer hitch for safety, and spray almost a quart of warm 15w40 on frame and underbody with a paint spray gun each fall. Works good so far.
A mid 70's Corvette would be worth taking to an under-coater to get it done right. That would be a Ziebart dealer around here.
