Stripped Lug Nut
Margo
I’ve got a stripped lug nut on a 4 wheeler that I can not get off. Tried different sockets, trying to drive a smaller one on. No luck. Any suggestions. Thanks.
Put a large nut over it and weld through the centre of the nut to the lug nut (welding both together), then use that nut to spin it out. A fairly common trick - especially for those ridiculous custom lock-socket vehicle lug nuts when people lose the special socket they need for them. The heat from the weld will also help loosen things.
At that point I go to my impact sockets. Fractional and metric. They are much sturdier and will grab a nut or bolt head and hang right on them. Hopefully you have impact sockets and hopefully the are six sided.
If that doesn't work them maybe a little heat but not too much or you can damage the wheel or the spindle.
An impact wrench helps also. Is the nut loose at all or still tight to the wheel?
Good luck.
Dave
Bolt extractor sockets (aka Twist sockets) work on many rounded off nut and bolt hex heads.
+1
They make kits especially for lug nuts. Any good auto parts store should carry them.
Drill down the center of the lug...increase bit size till you reach the threads and you should be able to knock it off....then replace the lug and nut
Nut is still tight to the wheel
That's what they make lug nut extractors for.
You choose the correct size. Hammer it onto the lug nut a little. Then when you turn the extractor with a breaker bar or impact wrench it bites into the nut allowing it to be removed. The more you turn the extractor the tighter it grips the nut.
By "stripped", I assume you mean the corners of the nut are rounded off.
What you use to remove the nut is kinda dependent on whatcha got to work with. If it was in my shop, I'd break out the 'hot wrench' (aka oxyacetylene torch) and heat it cherry red. At that point, it'll probably unscrew with a Vise Grip. If not, I'd just cut off the nut and stud with the torch.
I'm guessing you don't have a torch. What about an impact wrench? Nut extractors kind of need an impact wrench to work.
There is a simple, cheap tool called a "nut cracker" or "nut splitter" that will break a frozen nut in half, assuming you have enough room to get it on the nut.
Welding on a wheel with a mounted tire can cause a violent explosion due to rapid pressure buildup and a chemical reaction called pyrolysis. Always remove the tire from the wheel before welding or applying open flame.
Why It Explodes
• Air expansion: Heat raises the temperature of pressurized air inside the tire, rapidly increasing internal pressure.
• Pyrolysis: Excessive heat breaks down the rubber's organic materials without needing oxygen. This creates flammable gases and internal pressure that can spike quickly—sometimes exceeding 300 PSI and 1,000°F in just a couple of minutes.
• Weakened structure: Heat degrades the rubber and rim components, making sudden structural failure or bead blowout far more likely.
• Delayed blasts: Explosions do not always happen while welding. Pyrolysis and gas buildup can trigger a blast minutes, hours, or even a day later—including during reinflation.
Why Deflating Alone Is Not Enough
• Trapped gases: Even if a tire is flat or the valve core is removed, heat can still trigger pyrolysis and generate pressure inside the casing.
• Reinflation hazards: Welding on an assembled wheel has caused fatal explosions later when workers reinflated the tire.
• Severe projectile force: Blast forces can throw rim parts or multi-piece wheel components at lethal speeds, as documented in incidents reported by the Forestry Safety Society of Nova Scotia and the Los Angeles Times.
This was taken from gooooooogle ai, so I don't know if it is entirely accurate, but after watching how fast the pressure rose in the video after the welding had stopped makes me think it can't be far off.
