Stripped Lug Nut
I had one like that last year, I took a grinder and split it almost to the threads, then cracked it with a small chisel.
My question to all that say to split nut with a grinder, how do you get a grinding wheel on a lug nut to slice it without grinding into the wheel itself? I have had a lot of luck using a socket that, if you look at it from the end is lined with little pins. As you push socket on, the pins retract and the ones that don't grip the odd shaped nut. I was skeptical at first because I think it is one of those TV ad type tools, but it really does work. JM2C
That handy oscillating multitool could probably get into that tight spot to split it. If not cut a couple of notches to catch it with a chisel and walk it loose. I’m sure you have been soaking it with penetrating oil.
