I have an MF275 w/ 4.248 that ran five years ago, but sat in a field since then. I've replaced the lift pump, filter, and rebuilt the CAV, and I have 200psi in all cylinders (after adding a bit of oil to each cylinder). All injectors pop at 2250psi. Just about gave up trying to get it to start, when I found the block heater plug, and on a warmer day this Spring (about 75F) it surprised the heck out of me by actually starting, after daily attempts for several weeks. It took a bit of ether, as well. Not having topped up the oil, coolant, etc. I turned it off after about 15 seconds, although it seemed to be running fine.
Since then, I've tried daily for most of a month trying to duplicate the event to no avail.
[b:418a7da143]Are there any old tricks to get these things to start with such bad compression? [/b:418a7da143] I feel like if I can get it to run awhile, the rings might loosen up and the compression might improve.
When I try to start it, I do get grey smoke out the exhaust.
I've tried supplying hot intake air from a heat gun, higher flow air from a shop vac, and even tried pouring a little oil into the intake manifold (going into the injectors is really painful since you have to dismantle the fuel system).
