Frarck
I fail to understand what is going on and where to look next
Tractor was running fine. brought it into the shop and changed the oil and oil filter, now the engine is stuck. Can anything other than stuck pistons be the reason. Cannot turn the engine over with one rear wheel jacked up and the plugs removed and in 3rd gear on my 2n. Did nothing else other than a simple oil change.
Any suggestions please my email is [email protected]
The problem indeed was bad starter. Forgot about Murphys Law
Anyway going to get a new starter. The old one that has been there since 1945 bit the dust.
Next time it does this put the transmission in high gear and rock the tractor back and forth by hand, with the ignition off of course. A small twitch of the flywheel is all it takes to pop it loose.
