stuck flow control
mater
1967 ford 3000 gas burner...the problem i have is that the flow control valve is stuck and wont come out..have put pb blaster and wd 40 ...how can i remove it.. had read numerous post no has said how to get out....back story tractor has sat for 12 years,got it running and took all hydraulics apart and rebuilt them,except foow control valve that is stuck
thought about drilling a hole in it and run a screw in it and using slide hammer to pull. my thinking is if it is stuck it will be scarred and will need a new one
Just so we understand what you're trying to do here...
Do you have the lift cover off the tractor?
You will not get that valve out without disconnecting a bunch of stuff inside first.
Then when you do fix what ever is wrong with it and get it working you will never use it.
In 15+ years of running these 3 banger Fords I have never once needed to adjust the flow control.
ultradog i purchased tractor 3 months ago,yes i have cover off and have taken flow control rod and leveler and the pipe that bolts to the flow control housing.i have the i & t service manual,isnt valve supposed to move freely inside housing? filters are clean, unload valve is free , new chevk valve and piston has new oring. control valve moves freely. trying to cover all bases before i install lift cover again.
thanks for reply sean. i have #5 out and 12,2 off and out #22 pipe off and #9 the valve is stuck....is the #9 valve supposed to float freely?
#5 is restrictor pin assembly #2 is spindle knob assembly#22 is rigid tube and #9 is the plunger/valve that is stuck
ultradog what function does the flow control exactly perform and will it completely block off fluid passing to lift housing? i try to be proactive instead of reactive ,working on old stuff has a tendency to have ripple effect..am i worrying about nothing here? going by flow chart in repair manual its says that flow control valve binding can cause lift to be inop. i have rebuilt hydraulic pump and lift assemble, installed new check valve,maded sure unload valve moves freely, and flow control was last thing on my list to address before reinstalling lift cover....thank you all for your assistance
The flow control diverts some of the flow for the 3 point lift to control the speed of the lift. Turning the knob in one direction (clockwise I believe) diverts more and slows it down, the other direction diverts less and speeds it up. I don't think it can ever divert enough to make the lift stop working altogether, it will just lift more slowly or more quickly.
thanks so much for answer,at this point i am not gonna try to remove valve anymore. and just put top cover back on and bleed system and see what happens..thanks everyone for the help..much respect to yall
