I just purchased a new-to-me 1960 IH 340 tractor with an IH 2000 loader on it. Hydraulics seemed to be working great when it got here, loader worked fine and hitch worked fine, however there are some minor leaks; I figured that we could top off the hydraulic fluid as needed until proper repair can be made.
Well I guess I didn't top off soon enough because tonight I went out to test the brush hog; when I got up onto our hill the loader AND bush hog both went down (slowly) and both the loader levers and the control for the rear hitch to the right of the drivers seat stopped doing ANYTHING. Also the power steering stopped having power. Am assuming I am out of hydraulic oil. I shut down in the field because I can barely steer and I didn't want to destroy the hydraulic pump. Tractor is sitting sideways on our hill, on a somewhat slight but definite slope, maybe 10-15 degrees, with the clutch side uphill. I have ZERO idea how much hydraulic oil is in there, nor what kind of hydraulic oil is is (yes I know it is supposed to be Hy Trans but I don't know what the previous owner used.) I read on here that the hole for full is under the clutch platform which means that with the tractor being uphill, so I am afraid that it might get overfull if I fill it until oil comes out that hole.
So my questions are this:
** Does anyone have any idea how much (guestimate) hydraulic oil I should add, or should I fill it to the hole under the clutch platform and take a chance on it being over full? If I do that, will too much oil blow out the pump, seals, etc.??
** I know you are supposed to use Hy Trans in this tractor, but are there any oils at Tractor Supply that might be OK to get me out of the field at least? Nearest Case IH dealer is over 50 miles from me, which means a day off work -- if it is a choice of going 50 miles for the Hy Trans or destroying the tractor I will go get it if I have to, but if there is something from TSC (6 miles away) that could at least get me out of the field it would sure help. I was looking at TSC hydraulic oils but am not sure which, if any, would be even close to Hy Trans.
** This may be dumb, but if I am too low on hydraulic oil, which is also the transmission oil for this tractor, can the transmission get out of first gear or anything like that and cause me to have a runaway down the hill from this field? The hill is pretty steep going down.
Here is another question a bit less urgent, but concerning --
** The IH 340 Operators Manual says to turn on the Power Take Off you should press down "lightly" on the large lever to the right of the driver, push in the button, and pull up. But on my tractor this is anything BUT "light" because I actually had to stand with all my weight on this lever and try to hold the tractor with clutch only which is obviously not a great idea. It was still hard to pull. Does anyone have any idea what's wrong that could make the PTO lever almost impossible to move? I mean it does move, and the PTO works, but whoa is it hard to turn on and off!
I have driven another brand of tractor since I was a kid, but this is my first International. So thank you all in advance for your help!
