I took the 51 out yesterday, changed the oil and lubed it. Put about an hour on it and then let it sit. When I tried to re-start it last night it spun like it had no compression. That"s because it doesn"t, ALL 4 intake valves are stuck open. The gas does smell a bit sour but the tractor ran great. Is it possible the bad fuel caused this? I can"t see how the oil I used would have only caused the intakes to stick. I"m pulling the intake now and will soak the stems with PB Blaster, ATF, or solvent if I need to. I"m going to drain and flush the tank. Not sure if I should change the oil again. Anyone ever seen this before?
Thanks!
Thanks!
