Stuck John Deere B Revival
Tester was not full enough to accurately tst the freeze point. It needs to be up to that cross hair looking deal at the top of the tester there. I use a couple similar testers and they act that way if not full up. Had false readings many times if it was not full. I also compare it to those test strips for the diesels in the coolant which has a freeze pad on them. Both seem to test quite close .
I did see that after the fact and tried to retest. The test result was the same. she was mixed a little weak. My other 2 tractros sitting there were at -34.
